TwinTurbo.NET: Nissan 300ZX forum - Yea, that is how I set the base idle but the tech doc says:
Subject Yea, that is how I set the base idle but the tech doc says:
Posted by Andy_M on April 01, 2010 at 8:31 AM
  This message has been viewed 197 times.
In Reply To I did, but maybe I didn't follow the right procedure.... (n/m) posted by Andy_M on April 01, 2010 at 08:21 AM
Message "Automatics should idle 50-70 rpm higher when put in neutral. The engine will tend to idle no lower that 700 rpm, so I would suggest turning the screw counterclockwise until the rpms just slight start to rise. "
My idle drops a LOT more than 50-70 rpm when I put it into R or D from Park, so maybe the right question is what could be causing the excessive idle drop ?
Andy_M
atmorris@ptd.net (home)
